Reluctance calculation when the cross-sectional area is not constant.
Generally, when performing basic reluctance calculations for E-cores or I-cores, the cross sectional area is always constant over the element considered and the following equation is used:
Reluctance = Length / mu * Area
I need to calaculate the reluctance of a 'cake slice', where the cross-sectional area A is a function of the length... If you imagine the 'cake slice', as you move away from the centre of the cake, the cross-sectional area increases...
I have tried forming an integral, but I have arrived at the suprising result that the reluctance of my 'cake slice' section is independent of its radius.
Given that I need to develop an explicit equation, does anyone have any advice on how I should perform this reluctance calculation?
Thank you for your help.
Best regards,
bpelec.
Best regards,
bpelec.
RE: Reluctance calculation when the cross-sectional area is not constant.
