How to patern ?
How to patern ?
How to patern ?
I would like to know why is so hard or inpossible to pattern
hole on cylindrical surface. I make model in SW2005. I have picture but dont know how to attach it on this threat.
bye Tomaz
RE: How to patern ?
What type of hole are you trying to pattern?  What type of pattern are you trying to do?  There should be no problem with a simple linear or circular pattern.  Cannot say I have ever used any other types for awhile.
RE: How to patern ?
roscho ... How Can I Show An Image In A Post  FAQ559-1100
Work through the SolidWorks Help > Online tutorial > Pattern Features. It explains, step by step, how to create a patterned hole on a cylindrical surface.
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of
RE: How to patern ?
Is the hole on a plane or on the face of cylinder?
Is it a Hole wizard hole or a sketched hole?
What are your steps in producing a pattern?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: How to patern ?
thanks for showing picture here is link:
http://img333.imageshack.us/img333/2879/mala4je.jpg
I hope it will work!
As I can see is quite lot interests for my question!
I want to put fastener in two lines in assembly.
On picture you can see cylindrical plate green one and another
steel plate white one. The green one has radius 7 meters.
Another thing is that between this two steel plates is rubber which has 3mm thickness. This rubber has smaller hole then steel plates. This is not so important!
Perhaps I will post another pictures of my model.
I used hole wizard with all parameters of positioning, hole properties ...
I think that It have to work with linear pattern. But when program asks you for direction it accept just straight lines not lines with radius.
I hope that you understand me!!
Thanks for all your replies!
tomaz
RE: How to patern ?
Roscho, did you work out the tutorial that CorBlimeyLimey pointed out?  What are you trying to do that is not shown in the tutorial?
Flores
RE: How to patern ?
You'll want to use a Circular pattern or curve driven pattern.
Jason
RE: How to patern ?
When working with cylindrical bodies, for a linear pattern when you have no straight edges, you have to select the dimension locating the hole in the direction you want to go.  I looked at you picture but still do not understand where the hole is (too late at night, my eyes are tired).
RE: How to patern ?
Thank you all I solve the problem!
Specially CorBlimeyLimey and smcadman!
The online help helped me!!
Roscho.
