private property bridge beam size
I am getting ready to demolish an already collapsing bridge on my property. It's made of 7 steel gas pipes, each 25' long, 8 1/2" in dia., with a pipe wall thickness of 3/8" thick. The actual span is 22' long by 12' wide. I'd like to replace it with I or H beams, and capable of holding a 10,000 pound load driven over it. I will be using steel grating as the surface material. There will be concrete embuttments at both ends of 24" thick. From the embuttment surface to the road grade is 19", and the bridge will not have a slope. I prefer a 4 beam design so there will be a pair with some separation on each tread side. Any thoughts would be greatly appreciated.
RE: private property bridge beam size
Hg
Eng-Tips guidelines: FAQ731-376
