easiest way to rustproof carbon steel that can withstand scraping
I have some carbon steel straps
(length=10" xsection: .06"x1.25")
that see some friction and some humidity (indoor environment).
Ideally, I'd like a wonder paint that is very tough, completely
rustproof and can't be scraped off, but that all seems mutually
exclusive.  I could even see period application of furniture wax or
similar working.
Are there any FAQs or references people can cite, so I can review the
available approaches and technologies ?
Thank you,
RE: easiest way to rustproof carbon steel that can withstand scraping
Take a look at the products available from
http://www.magnaplate.com/
You could coat the parts with Teflon.
Tunalover
PowderCoatings are very tough and durable. They all have pinholes though.
Zn rich primer with epoxy top coat.
There are a lot of coating systems out there.
Start with Glidden.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
You want reliable abrasion resistance and corrosion resistance in a polymeric coating?  Epoxy powdercoat.  You want just abrasion and corrosion resistance?  Hot-dip galvanize.  If it's indoors though, you may get away with merely a heavy zinc electroplate coating.
how much cost can you afford?
I have been reviewing my original question and the
very thoughtful recommendations.
I went to the local hardware store today, and the shopkeeper
suggested Car Wax and/or boiled linseed oil.
I mentioned it was for indoor use, but I think I'm after a "farmer's almanac" approach that people would use on their favorite handsaw- As long as it's not oily and
1) it's  cheap
2) it's ok if it's periodically reapplied
thanks again for all the replies.
