Stainless Steel Banjo Bolt
Does anybody have any experience of using SS304 matl for a banjo bolt?
Stainless Steel Banjo BoltStainless Steel Banjo Bolt(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Stainless Steel Banjo Bolt
SS fasteners can foul just as easily on assembly as disassembly...I never assemble SS cap screws without some form of lube, never! In some applications where lubricant may interact with the product, O2 etc., several forms of wax can be used.
SS banjo bolt? I don't see a problem as torque is not an issue in most cases---copper or aluminum sealing washers are rather soft. I do see one issue, that of loosening in vibration service. Not a common problem but, none the less...a chemical locking agent would cure the problem as well as lube the assembly, but dissambly could be a problem.
Rod
