SW 2006 Mirrored parts lose faces
When I modify almost any part in an assembly I get rebuild errors due to mirrored parts lossing references to faces.
The modification can be to a part in the main assembly or in a sub-assembly and the errors will show up in all assemblies with mirrored parts.
Talking to tech help has showed that this is a SW issue, not operator or hardware. A service pack request has been issued(#279672) and should be out with the next service pack(two months ?). Untill then I will stick to SW 2005.
I am working on a Dell Precision 370 workstation with Intel Pentiun 4 3.2 Ghz, 2 Mb Ram, NVIDIA Quadro FX 3400, XP Professional, SW 2006 clean install.
RE: SW 2006 Mirrored parts lose faces
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
