Taguchi's L8 Orthogonal array
Can anyone please help me to understand how I can design the Taguchi's DOE (Design of Experiment). I am not aware about the rules.
I came across this equation
Ln(2^K)
Where n= number of experiments
2 = levels per factor  (i.e. High & Low )
k = number of factors
But how to find N
I have seen some examples form which I am assuming N = K-1
Can anyone please explain me how to design this experiments and what are the fundamental rules?
I am very thankful for any suggestions and help, Thanks a lot in advance !
Jignesh
RE: Taguchi's L8 Orthogonal array
See if you can find a copy of Bob Pease's piece,
"What's all this Taguchi stuff, anyhow?"
<humble opinion>
There are a couple of valid ideas at the core,
but..
the _program_ is snake oil.
</opinion>
Mike Halloran
Pembroke Pines, FL, USA
The L8(2^7)experimental orthogonal array looks like this:
           columns
No. exp    1   2   3   4   5   6   7
1          1   1   1   1   1   1   1
2          1   1   1   2   2   2   2
3          1   2   2   1   1   2   1
4          1   2   2   2   2   1   1
5          2   1   2   1   2   1   2
6          2   1   2   2   1   2   1
7          2   2   1   1   2   2   1
8          2   2   1   2   1   1   2
"1" means a factor at lower level and "2" means a the same factor at higher level, e.g. temperature at 1 =20deg and temp. at 2 =50 deg.
No. experiments are runs you have to perform to measure the efect of factor 1 (column 1).
The design for 7 factors need 56 runs which is fairly considerable compared to a full factorial that would need 2^7=128 separate runs.
m777182
I am looking for an array of The L8(2^6)experiment.
Can anyone help me please.
I have to correct my answer to Jigneshpadia2002:the design for 7 factors needs 8 runs. Each run is done at levels shown in columns 1..7.
m777182
m777: You mentioned that I need to do 7 X 8 runs = 56 runs ! But I have some other information saying 8 runs will explain all the information and I do not need to perform 56 runs !
I hope I do not require 56 runs. What is your take on it.
Can we use the same format for 6 parameters? This is questioe asked by nedian.
My take will be yes?
What do you say ?
I have corrected my answer already: you need 8 runs. For six factors I do not have a design table; however it is neither in my Statistica. I 'll try to construct it over the weekend time.
I think that the efficiency of the Taguchii design ceases with less factors.
m777182
