thermal analysis, 20C/hr heat rate
Is it possible to have a model of a pipe in Pro/Mechanica an apply a heat rate to it so that it heats up at 20C/hr. This is to find how much the temperature of the outside f the pipe lags the inside temp at certain heat rates.
RE: thermal analysis, 20C/hr heat rate
