circle dimesion does not change
In AutoCad 2005, if I have a dimensioned circle and change the diameter through the use of the properties dialog box, sometimes the dimension will automatically change to the new value and sometimes it doesn't change. Why? What is the setting that regulates this? DIMASO is on.
RE: circle dimesion does not change
Options...user preferences...Make dimensions associative.
http:
"Everybody is ignorant, only on different subjects." — Will Rogers
