Multi flexible subassemblies to work with parent
I have 4 subassemblies that are flexible and by moving one I would like the rest to move accordendly to the parent.  But it seems that each one has its own control and does not react to the parent changes.  All subassemblies are the same.  Is there something I missed?
RE: Multi flexible subassemblies to work with parent
Flexible always them to move independent within the assembly. You will have to setup mates that control the other compoentn to follow your movements.
Retgards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Or abandon the Flexible SubAssys, and insert the same SubAssys and use Configurations to control all the movement.  I remember having to do this before Flexible was available.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
