Folders still held hostage by SW after it's closed?
I've experienced this often, and another user has just come to me about this.
I work over a network. Typically I work inside a single folder which holds all project files (parts/assemblies/drawings). On occasion I've realized that I named the folder incorrectly, and I want to change it. If I attempt to rename with SolidWorks open, it almost never works...understandable. But I've noticed that even after SW has been closed, I still can't rename it--it says that it's still being used by 'another person or program.' I have to reboot my computer to break the link. Any ideas on why that may be--could it be my computer that's still accessing the folder?
Brian
Brian
RE: Folders still held hostage by SW after it's closed?
2) I have seen this before and sometimes I just have to wait a little longer after I have closed SW... like maybe 5 minutes, to ensure all SW has Cached out.
3) If you close SW make sure your Memory is caching out, if not then SW is not closing, this could be either because of Windows or a repair to your SW needs to be performed.
4) If you have more then one person seeing this, if could be a network issue. Try something locally and see if you get the same result.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I just performed a quick test, & I didn't see the same problem locally. I'll test once more and then go after the network guru--the problem may indeed be the network.
Thanks for the quick response...
Brian
I finally convinced my IT guy to let me move all my solidworks files back to my local drive and back up from there. Presto, no more locked files and my crashes have decreased VERY dramatically. I'm lucky if it goes down once a day, versus every couple hours or so. I've been pushing it pretty hard this past week with a thousand-part assembly going through a photoworks rendering process.
While this is not much consolation for those in a multi-user environment, there is hope for single-users if you can work out a backup strategy for these very-important files.
Solidworks does not seem to play well with networks.
If you IT wants it to be on the server, then you need to look at PDMworks as a vialbe option.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Solidworks saves and stores information on the RAM which needs to be cleared before renaming any folders. This usually involves closing down all SW files and shutting down SWorks.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
