Is it possible to read text in to mathlab from excel?
RE: Is it possible to read text in to mathlab from excel?
Are you referring to MATHCAD? or MATLAB?
For Mathcad, there is an Excel component as well as the capability to reading comma separated value format.
TTFN
Yes I was! Sorry! I cant find out how to do this do you have an example? I would like to read in the text string "200x200x12" for display in mathcad.
Check the enclose example for one number.
         http://cuky2000.250free.com/Str_No.pdf
NOTE: If you have a series of string values in excel, you may import this as a vector and apply similar logic converting string to numbers.
Good luck.
