Trending in VB
Trending in VB
Trending in VB
  Does anyone know where i can get info or even better code for trending. I want to place a trend in my project for a variable but don't know where to start.
Thank You,
Merlin Knight
RE: Trending in VB
Can you describe the project?
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: Trending in VB
Hello CajunCenturion,
  I am wanting to make a trend that will trend temperature. On the right side it will have the temp range that i am wanting to make changable . Also , i would like to have a changable time constant at the bottom to be able to spread out the readings.
Thank you,
Merlin Knight
RE: Trending in VB
VB6 includes the MSChart.ocx, which should be able to produce your trends
Samples of it's use can be found in the sample shipped with VB6.
