Background Color To White
Want to change the background of new parts to plain (not graduated) and to be white. I assume the ug_english.def file. What lines need to be changed?
TIA
TIA
Guy Edkins
RE: Background Color To White
Guy Edkins
Guy Edkins
No, this alone won't make the background white, just plain. I don't know of a setting in the ug_english.def file to set up the plain background color. But there is a way around it; set the background default to graduated, then change all of the default colors in the lines for the graduated background colors (just below the default background type lines) to the number that corresponds with white.
I wish I could be of more help, but without NX2 loaded, I can only going by memory and my copy of the NX1 ug_english.def file. Someone else here may be able to point us to where the plain background default color setting is.
Remember to save a copy of your original ug_english.def file so that you can easily restore it.
Now, you need to know FOR SURE which customer defaults file you're using. If you're working in English units, then it's ug_english.def. If you're working in metric units, then it's ug_metric.def. If you're working in a custom environment, such as the GM PDL Toolkit, then you need to find the .def file that the custom environment is using.
When you have found the correct customer defaults file, search for:
UG_shaded_graduated_background_color
or
UG_wireframe_graduated_background_color
Each individual line is an RGB value (red, green, blue). Set all of your values that are not commented out to 255 & that will result in your background always being white, regardless of whether in shaded or wireframe display mode. Don't worry about the background being set to graduated, as there is NOT a setting (that I am aware of) for controlling the background if you set it to plain.
Hope this helps.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
You explained what I was trying to say much better than I did.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
