Spliting Parts and Coping
Is there an easy way in SWX to copy parts that have been split and have the parts reference the new copies.
I'm creating a housing with top and bottom sections, each half having an interior and exterior cover. In all I have 7 part files. One is the original design, the 2nd and 3rd parts are split from the original master(using the split command) and the 4th, 5th, 6th, & 7th are split from the 2nd & 3rd. I would like to make some changes but would like to maintain the original files. Therefore I would like to copy all files in the group and have the new split parts reference the new master(s).
Master_r2
2nd_r2
4th_r2
5th_r2
3rd_r2
6th_r2
7th_r2
Master_r2
2nd_r2
4th_r2
5th_r2
3rd_r2
6th_r2
7th_r2
RE: Spliting Parts and Coping
Within the assembly, you can go to File > Find References, and copy all the parts of the assembly into a different directory for use elsewhere.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
