Motor Insulation resistance was bad
Dear All,
Please, I need some advice,
I have a problem with my motor. The motor with 380 V, 3 phase, 50 Hz, 2 pole, 150kW suddenly shutdown after running around 2 hours. The 50G relay (groundfault relay) was actived. I measured insulation resistance by 500VDC and winding resistance , result :
R phase 2.55 Mohm/ 0.0135 ohm
S phase 2.50 Mohm/ 0.0136 ohm
T phase 2.60 Mohm/ 0.0135 ohm
Based on this, I started motor again until 4 hours and I measured current (ampere) and voltage each phase were normal and vibration was normal ( there was nothing electrical problem ). Vibration at 2H (maximum value) overall below 1.5 mm/s RMS. I take with Fmax 200 Hz and resolution 6400 lines.
I stopped motor and I measured insulation resistance was increased each phase around 50 Mohm. I conducted heating up the motor until insulation resistance reach 150 Mohm.
After 3 days, I checked insulation resistance and I got insulation resistance were decrease (each phase) become 3.50 Mohm
Would you like to explain me:
What is problem with my motor?
Why insulation resistance decrease in 3 days?
Please, give me some advice for this condition.
pjono
pjono
RE: Motor Insulation resistance was bad
Maybe opening the motor to do cleaning and service would help. You could open one cover (depending on the IP-degree, though) and use your flashlight to look if it sounds reasonable.
Does this make sense to your application?
Yes, after 3 days, IR was become low again.
Whait is "use flashlight" mean, Sir?
Would you like to explain about that, please?
Yes, motor in outdoors.
Thank you for your explanation.
Any way, thank you for all to give me some advice.
jonos
