Kawasaki KMX32? Kobelco 916?
Anyone familiar wiht the Kawasaki KMX32 mobile valves?
I'm having a bit of a problem with a Kobelco 916.
Support for this in Scandinavia is limited.
RE: Kawasaki KMX32? Kobelco 916?
A well hidden switch releases the electronic control system and the excavator now operates pretty good on the hydraulic control system.
This link is to a document describing a newer machine but the pic on page two should give you an idea.
I assume that my machine now uses two linear springs (the two piece grey line) to approximate the maximum power curve on the Q-P diagram.
A working electronic control system should be able to follow the continues curve, hence make better use of the engine power.
Am I on the right track here regarding my understanding of the system?
