Microsoft Access: transfer data from a form to a report
I have a form with a combo box with names of library's in it and a preview report button. I created a report to show all the library's with it's data. When I click the preview report button it shows all the data. And a message pops up "The expression On Click you entered as the event property setting produce the following error: The object doesn't contain the Automation object 'Program_Name'." How can I show only the library select in the report? thanks
