V5R15 Drafting Text Properties Menu-Font Size Field Width
The Text Properties menu has a pull down for Font Size. This menu field has a size width limit of 1 decimal place. When working in MM mode it is fine as the font size does not go beond 1 decimal place. When in inch mode we usually need at least 3 decimal places (eg .125, .160).
When working in inch units the pull down list will display .080, .110, .120, .140 sizes as .1 (rounded to 1 decimal place) and list .150-.200 sizes as .2 (rounds up). Is there any way to change the number of decimal places shown in this menu. It is hard for the user to determine what size of font is being used?
Note: if you right click on text and select properties you will see the pull down list has 3 decimal places shown for Size
RE: V5R15 Drafting Text Properties Menu-Font Size Field Width
Search the FAQs and forum for more information on Drafting Standards.
The text sizes are set in General, Allowed Font Sizes.
