Rebar Requirements
Rebar Requirements
I am designing a concrete columm to support (4) 12" x 12" timber columns that form a square with 6" space in the middle. The Timbers have a small compressive load (3K each) and are only this large for aesthetics. Ideally I would like a 30" x 30" x 72" column on top of a footing to support these timbers and attach stone work to.
To meet ACI reinenforcement requirements a a large amount of rebar is needed since the column is so large even though the loading is minor.
Is there another way to approach this problem so I don't need so much rebar?
RE: Rebar Requirements
