material thickness calculation
Looking for direction. I haven't had to do this in a long time.
I would like to calculate the thickness required to support 1000lbs on a piece of glass 8" wide. Support will be on either end (.25" on either end of the glass). The glass will be 8' long. No specific glass has been selected at this time. Will start with silica glass but more than likely move to a cermaic type glass (Robax).
Point me in the correct direction.
Thanks.
jl
Thanks.
jl
RE: material thickness calculation
After that, it's just basic mechanics to calculate the applied stress. If it's like a 2D beam or slab, then simple wL^/8 or PL/4 will get you a moment that allows stress calculations. If it's a plate bending problem, then you can either make conservative assumptions, find your friendly plate bending tables to get moments per unit width, or you can use a simple shell or plate bending FE calculation.
14159
