initial pressure
initial pressure
initial pressure
Dear friends,
I am simulating a rigid body container with deformable body inside (gel).  These two are initially in contact, and there should be initial pressure inside the gel, as well as between the gel and rigid body.  My question is, how can I apply the pressure there?  This pressure is impoprtant in that it provides normal force between the gel and container and affects the frictional force between them.  Thanks!
RE: initial pressure
You should be able to apply pressure to any surface
corus
