generator temp rise
generator temp rise
with a standby application, is it typical to use a temp. rise of 105 deg. C or 130 deg. C? We are concerened with the heating affects of harmonics and are considering specifying a low temperature rise for the alternator.
RE: generator temp rise
Some people in attempt to gain thermal margin will specify that the machine be limited to a rise one insulation class below the actual insulation class of the machine.
One day my ship will come in.
But with my luck, I'll be at the airport!
