Problems with Library Features in 2005/2006
We had problems with Library Features we use for years in SolidWorks. All contain partly constraint cut features including configurations.
It seems that the not fully constraint LFs have problems. I cannot insert them on a surface. There is an error message that it is unable to insert the LF.
Does anybody have similar problems?
RE: Problems with Library Features in 2005/2006
Yes, I had the same problem yesterday using SolidWorks 2005 SP4.0.
What I did was rotated the library feature and it came in OK after saving the feature to the library. That is not what I wanted so I returned the feature to its original shape.
Then I tried placing the part on the back side of my sheet metal part and it came in OK. I did not have time to look into it further.
Bradley
It seems that not fully constrained LF's cause the problem. If I change this LF so that you have to give in a reference which fully constraints the LF there is no problem.
Thing is his feature should be movable over one axis.
