Geometric Tolerance frame location
All,
 I was curious in SW2005 if there was a way to switch how the leader is attached to the Geometric Control frame? All mine always snap to the top of the line with the leader attached at the lower edge. Can you get it to attach to the top? Like the datums do. Thank You
Brad
