Microstation V8-Getting Angles into Azimuth Mode
Greetings,
I just changed over to MSV8, I am handling lots of data from TMS and my surveyors. I would like to set the angle to 0 degrees to the top of the viewer and have the degrees increase clockwise, in azimuth mode, like a normal compass. I am stuck with 0 degrees to the right(x-axis) and an increase counter-clockwise. I am new user so I am bit stumped.
Thanks, Terrence
RE: Microstation V8-Getting Angles into Azimuth Mode
Settings>Design file>coordinate readout
This will let you set your coordinate readout to azimuth instead of the default bearing.  Also set your accuracy here.
Mike
Thanks Mike, Ter
