Order of Parameters ?
How do you get the Parameters in a Start Part to show in the order You Want? I noticed that after typing my parameters in my Start Part (in order that I wanted), it does not show that way when I use it? "Title_1" is on bottom while "Title_2" is way on top???
Thanks!
Wildfire 2.0
-Art
RE: Order of Parameters ?
I believe they're in order of creation.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
When you open Tools-Parameters, you can sort them by clicking in the column heading area. Click the same column a second time and the order will reverse.
To get prompted for parameters in your desired order requires a toolkit application. There are some free ones available for parameter entry.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
