Custom properties
Custom properties
Custom properties
Is there a way to bring existing custom properties from a part that has all the info set up, to an existing part that has no custom propertiess assigned?   I would like to bring my standard custom properties from my generic part template to another existing part.
RE: Custom properties
Can I suggest you do a on this forum first before posting.  This topic in every form and flavour has been asked at least once every month.  If you find the answer may I suggest you put together a FAQ.  Thanks
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
Dubleya,
I don't mean to flame you for not searching....But searching the past postings and the FAQ should be done before posting.  I have noticed a lot of new users just post incomplete questions....I have no idea how they expect to get an answer.  I've also noticed an element of lazyness or should I be PC "lack of research" before posting.  If you do some searching and post an answer to your question you will earn a [img http://www.eng-tips.com/images/star.gif
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
I don't mean the Stefan Berlitz "Copydoc" macro.  The properties I want to copy are the ones you set to fill out drawing title blocks, etc.  For instance in an open part, go to "Properties" and see a list of items to fill out to be able to automatically have the drawing title block fill out.
WDickman ... The FAQ section here is full of good advice. One of the most useful FAQ was created by SBaugh
Helpful SW websites every user should be aware of  FAQ559-520
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
