ROPS, rollover protection
I have been asked to look at a ROPS design for a concrete delivery machine.  Does anyone know if (in the US) this can be done on a structural program like Multiframe or RISA, or does it require a nonlinear FEA analysis of some kind?
I think the relevant spec is SAE J1040.  Maybe CSA B352-M1980.  Are there others?
-Mike
RE: ROPS, rollover protection
I think you need to identify which spec you are working to. For SUV roof crush, for example, we'd have to use a non-linear code, because performance is defined in terms of intrusion.
Your other option is to design a structure that can be analysed by hand, which, combined with linear FEA for the rest of the structure, should allow you to predict its performance reasonably well. That's a higher risk approach, obviously.
Cheers
Greg Locock
Seems like I've read that bulldozer roll cages are designed to absorb a specified amount of energy, rather than being just a stress-type analysis.  But should be covered in Code of Federal Regs, I would think, if you can ever find it.
Thanks Greg and JStephen:
I am trying to get more info from the customer, also rummaging around the internet to see what I can find.  I currently have Multiframe and CADRE so I'm not sure I have what it takes to do this.  Things have probably changed a lot from when I did one of these in the late 80s.
Thanks again,
-Mike
Hi mrMikee,
FOPS and ROPS requirements are typically combined in the resultant cage design, depending on the industry.  For instance, for forestry mobile equipment, OSHA 1910.266, the FOPS requires a solid top and mesh sides.  A substantial FOPS can influence the structural design for ROPS and vice-versa.  Ref. SAE J1040, J231, J397.
From Greg's comments, it is interesting to note that use of non-linear codes have progressed into regulatory/safety evaluation requirements for automotive design.
Regarding JStephen's comments, I too have seen cages designed like this based on energy absorbtion via plastic deformation of the cage.
I think CSA Standard B352.0-95(R2004) covers the design and performance requirements for agricultural and construction equipment for ROPS
I appreciate the comments.
I was hoping to have more info by now but haven't made any progress.  Just wanted to say thanks for the help.
-Mike
