Mirroring a part AND drawing
We use handed parts quite frequently, and I am trying to come up with a way of detailing only one part, and using all that info for the mirrored part.
Here it is in real terms. I have an assembly file with a part called "left.sldprt", and a drawing called "left.slddrw". Now I want to create a file called "right.sldprt" and use the existing detail info for a new file called "right.slddrw"
I've done a bit of searching, and I'm only find half of an answer to my question, so any clear concise help would be greatly appreciated.
RE: Mirroring a part AND drawing
I use dash numbers to signify LH & RH.  I show them in the same drawing and identify them as -001 & -002.  Sometime I will indicate a mirror line if it's not obvious.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
We use the same practice as Heckler.  We typically detail the -001 and state the -002 is a mirror of -001.  We will show isometric views of both parts.
yeah, but I need seperate drawings for the left and right. how do I make the "right" drawing from the "left" drawing. All dimensions are already there, and all notes, they just need to flip somehow
Insert/Mirror Part - Make a mirror os the part and insert that into a new drawing or a separate Sheet.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I'm not having a problem creating the mirrored part, I am having a problem using the exisitng left detail sheet, for the right part. It seems rather a difficult task to re-use the exact same dimensions for a mirrored part. All the info is there, do I really have to do it all manually again??
Yes, you will have to redim the mirrored part.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I understand your problem.  I'm no expert, but I have not found a way to create the mirrored drawing you are looking for.
BLAST!!! (shakes fist in air)
thanx guys
Been there, done that... From all my research, there is no easy way.
Let's all send an enhancement request.
David
