Content of Combo boxes is not vvisible
While working with NX3 and TCE V9 we are working with two monitors. NX is displayed on the primary monitor and TCE V9 is displayed on the secondary. When working like that menus with List of Values are empty. If you move the menu onto the primary monitor the content is displayed. With TCE V8 it worked on both monitors.
Does anybody has an idea what you can do to make it work.
RE: Content of Combo boxes is not vvisible
With dual monitors config there are often problems like that. I don't know which video card is driving your monitors: with ATI FireGL family, very often the setting "open dialog windows on... <follow cursor> or <application's monitor> or <monitor #x>" can have drastic effects. Sometimes also, any dialog IS open but in background behind other windows, if it opens in a different monitor from the "parent" application window, so it is there but you can't see it unless you explicitely recall it (ctrl+tab, for example).
