Macro in QSave
Macro in QSave
Macro in QSave
I recently switched from AutoCAD 2000 LT to 2006 LT. My settings in 2000 were to Z(oom), E(xtents) under Qsave. When I switched to 2006 the same...    Z,E,^C^C_qsave  ... does not give me the zoom & extents capability that I like when I Qsave. Any thoughts?
Thanks.
RE: Macro in QSave
AutoCAD does not do those things natively as a QSAVE. You must of had a script running before. You will need to look how you defined the button before (probably in your mnu/mns file previously).
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: Macro in QSave
_zoom;_extents;^C^C_qsave;
ADT 2004
ACAD 2002
RE: Macro in QSave
borgunit - I think QSave is a built-in command, native to AutoCAD but "Z" is not.  Your suggestion to used _zoom should fix the problem - even spelling out extents should not be needed.
