What is the significance of word "Kernel"
What is the significance of word "KERNEL" in cad softwares?
N P Singh
What is the significance of word "Kernel"What is the significance of word "Kernel"(OP)
N P Singh Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: What is the significance of word "Kernel"
The kernel is the essential center of a computer operating system, the core that provides basic services for all other parts of the operating system. A synonym is nucleus. A kernel can be contrasted with a shell, the outermost part of an operating system that interacts with user commands. Kernel and shell are terms used more frequently in UNIX and some other operating systems than in IBM mainframe systems.
Typically, a kernel (or any comparable center of an operating system) includes an interrupt handler that handles all requests or completed I/O operations that compete for the kernel's services, a scheduler that determines which programs share the kernel's processing time in what order, and a supervisor that actually gives use of the computer to each process when it is scheduled. A kernel may also include a manager of the operating system's address spaces in memory or storage, sharing these among all components and other users of the kernel's services. A kernel's services are requested by other parts of the operating system or by application through a specified set of program interfaces sometimes known as system calls.
Because the code that makes up the kernel is needed continuously, it is usually loaded into computer storage in an area that is protected so that it will not be overlaid with other less frequently used parts of the operating system.
The kernel is not to be confused with the Basic Input/Output System (BIOS).
N P Singh
ACIS - owned by Dasault, makers of Catia and Solidworks. Neither of these programs use it. It is primarily used by Autodesk and their solid modeling packages, Inventor and Mechanical Desktop. Catia uses a proprietary kernel.
Granite One - owned by PTC, makers of Pro/Engineer. Used since the beginning of Pro/E, but only reently marketed as a kernel. Primarily used to integrate third party applications into your working environment that will allow you to read a Pro/E file without owning a seat of Pro/E.
Parasolid - owned by EDS PLM Solutions, makers of Unigraphics and Solid Edge. Used by Solidworks, MSC, Gibbs, and others. It has a export/import capability that will allow sharing of the solid model between any system that uses the Parasolid kernel.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
717-532-9181
ben_loosli@irco.com
