Editing cropped views
I have been working with cropped views and have wanted to edit them or delete the cropped view and return to the entire view. The help file said that you can right click on the view and select either "Crop View, Edit Crop" or
"Crop View, Remove Crop". When I do this I do not see either one of these options. What I end up doing is re-inserting the view and croppping it again. Is there a better way to work with cropped views. I am working on SW2005, SP 4.0
Thanks.
RE: Editing cropped views
When you RMB and do not see the edit crop view option go under customize menu....there you will see that the option is not activated.  Check the box it will work the next time.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
Thank-You Heckler.
Worked great.
