1949 relay
1949 relay
i have an old relay that i need help whith.
it is 2" widex3"long x1.5"high has 2 poles on each end and 2 in the middle. on the in side has 2 coils and 8 diodes.
all solid black sealed, used to switch 2 water pump motors when one got hot. need replacement no numbers or manufactor info.
thanks
we
thanks
we
RE: 1949 relay
Determine whether the voltage that energizes each of the coils and AC or DC.
Determine the voltage and current required for the load or loads.
You might advise the equipment associated - including manufacturer and model. However, finding a pdf file on the web for something quite old is unlikely.
You mention that the relay is used to switch two water pump motors. As I understand your post, one motor overheated. Is this a problem with the motor? What size? I assume that the motor must be a small fractional hp if activated with a small relay.
The diodes suggest DC coils or DC loads.
What more can you tell us?
John
RE: 1949 relay
i dont have any other info other than it was used in a johnston-pruitt air handler. they are no longer around.
was hoping someone would know about this unit and come up whith a diagram w/a part number that would lead to the companey that made the relay. thanks for your quick responce
thanks
we
RE: 1949 relay
"Our virtues and our failings are inseparable, like force and matter. When they separate, man is no more."
Nikola Tesla
