Commentary or examples for CMAA standards
The crane manufacturers association (CMAA) publish standards with design methods for cranes girders. But to me, the equations are quite confusing . Does somebody knows about some commentary or examples for these equations.
thank you
thank you
RE: Commentary or examples for CMAA standards
Past issues of AISE Technical Report No. 6 (Association of Iron and Steel Engineers specifications for overhead cranes) did include a structural design example pertaining to the crane girders. This example (about 11 pages in length) was included in the September 1991 and June 1996 issues of that standard. There is a new issue dated 2000 that I haven't seen yet, so I don't know if it contains the same example.
AISE does have a web site at www.aise.org.
I believe the methods used in the AISE example will follow pretty close with CMAA, although the loading combinations will differ somewhat. The AISE example is for a box girder section supporting a top running trolley.
I used this specs for decades.
Ernie
