Sustainable pressure
What maximum pressure (at 240m below sea level) is applied to a pipe (open ended at sea level) with a closed end at 240m below sea level?
RE: Sustainable pressure
Hi fletcher2536
Pressure changes with depth and therefore knowing the depth your pipe is at the pressure it see's at 240m is
   pressure= density * g * h
where density of sea water = 1010kg/m^3
g = grav const=9.81m/s^2
h= depth 240m
           pressure = 1010*9.81*240m=2277944N/m^2
regards desertfox
1010kg/m3 looks low for seawater density. We normally use 1025 or 1026kg/m3
StephenA
