Air supply to clean rooms
Where can I find a sechematic description with a block or flow diagram for the air loop supplied to the clean room starting from atmospheric air outside the building ?
Thanks and Regards,
roker
Thanks and Regards,
roker
RE: Air supply to clean rooms
That is a very general question and it depends upon your requirements viz., area classification, application, type of air handling system etc. However, here is a link for starter
htt
Come back if you have any specific thing to ask (and I will try if I can).
