Dimension a Screw
Dimension a Screw
I am trying to call out a screw spec. on a drawing. It is a M4 X 0.7 screw. Is there any other spec. to a screw other than the "M4 X 0.7" callout. What happened was the supplier sent us the screws as per the M4 X 0.7. But it failed our testing gages because they were a different "D" spec. I checked on various drafting standards. I could not find anymore information about a "D" spec. for screws. I would appreciate if anybody can give me soem information about this. Thank you.
RE: Dimension a Screw
You will find there the ISO metric screw threads Limits of sizes.
I cannot speak for the rest of the world but in Europe in the automotive trade it is normal to specify a DIN or ISO number to cover things like material, tolerance and finish/ coating.
Even if none of these matter, length is normal.
These might help.
http://www.rapoole.com/fasteners/table.asp
http://mdmetric.com/fastindx/inxtst.htm
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
