Reverse action of Attribute Extraction ?
After the use of the attribute extraction command, we get a text file in which the blocks data are included.
Is it posible to do, somehow, the reverse action?
to insert some or all of the data (name,x,y,z etc) into a blank drawing like block or points????
RE: Reverse action of Attribute Extraction ?
Yes it is possible. It would most likely need to be tweaked to your needs.
"Everybody is ignorant, only on different subjects." — Will Rogers
You can e.g. use Excellink (www.aac-solutions.cz/excellink) to bidirectionally link (export/import) your attribute data with Excel.
Vladimir Michl
