Interview tips for power supply design position (new Grad)
Hi all,
As you can tell from the subject I am a recently graduated undergrad. I have an interview scheduled for next Friday with Artesyn Technologies in MA. More specifically with their power group.
It doesn't have to be specifically for this company but what kind of technical questions should I expect for a new grad for a power supply design position.
To give you an idea here is a small part from the job description
"Assist other engineers in testing, analysis and design of high density, high performance, low cost power supplies, both AC/DC and DC/DC, from 100W to 2.5kW."
"Working knowledge of electrical simulation tool such as Spice or similar. Experience with Labview for automated electrical bench testing a plus."
Any tips would be appreciated.
RE: Interview tips for power supply design position (new Grad)
Understand and be able to explain the similarities and differences between BJTs and MOSFETs
Be familiar with the transfer characteristics of BJTs and MOSFETs
Be able to work your way through a differential pair
Be able to figure out voltage drops for combinations of diodes and EB junctions.
Note that the interviewers don't necessarily expect you get all the answers right. They DO expect you to understand HOW to get an answer.
Have an answer for where or what you want to be in 10 yrs
Dress and groom neatly; sit straight and don't slouch
If taken to lunch, don't salt your food before you taste it
Speak in a professional manner; avoid slang and IM language
Have clean and high-quality copies of your resume available
TTFN
If anyone else has anything to add as far as the technical questions go, it would be very much appreciated.
You might want to review their company's profile:
http://www.artesyn.com/media/pdfs/co_profile.pdf as well as other information you can glean from their website:
http://www.artesyn.com/powergroup/products.htm
This is SO much easier; it used to be very difficult to get any detailed understanding of a company's business and product line prior to interviewing.
"testing, analysis and design" is pretty much motherhood. The excerpt sounds like they'll let you try pretty much anything you're capable of doing.
TTFN
Do indeed check their website and see if you can come up with a few clear questions that, actually interest you, in the area they all looking to fill.
I know that there are many important things to be careful about at an interview. But technical questions seems to be the most important of all. At the end of the day, they really need to know if you are capable of "engineering"
So I really want to cover if not all but most of the possible questions that could be asked.
If anyone can think of any other questions it would be great
As an aside, I've worked with the engineering team there, and know a manager or two. Top notch company. I currently use thier parts in several of my designs.
Be very familiar with the basics of inductors. V=L*di/dt goes a long way.
What considerations are made in the selection of capacitors used on the output of a switchmode regulator?
What considerations are made in the selection of capacitors used on the input of a switchmode regulator?
What is the ESR of a capacitor?
If your analyzing the stability of a switchmode regulator, what would the IDEAL gain plot look like on a bode diagram?
Can you calculate the switching losses in a FET?
How about a diode?
In terms of testing...
- How would you measure the gate-source voltage of a high side FET in an H-Bridge or even just a buck regulator?
- How would you measure the current through the FETs?
- Do you know how to use a spectrum analyzer?
that's all i got...
If you want to be in the testing, analysis and design in electronics then tell your employer why. He really doesn't expect you to know much other than you are book smart at this point in your profession. Tell him that you would like to be an on hands person to do design, analysis and also work with test equipment. Most of all tell him or her you want to learn from him or her all you can about the design analysis and testing business and mean it.
Be sure you review all you can about inexpensive power supplies ,low power types, in the range they are looking for.
The job looks like it will be in a lab with you working with a small amount of people, so all you need to do is click with this group.
It's a tuff business. These types of job will last about a year if you are luckly even if the boss tell you it is for ten years. Remember electronics is very go-go and big bucks for shorts periods at working for many companies in big cities. So alway be ready to be looking for another job and always keep up with the technology. Be nice to all your co-worker because you will be running into the same people in different companies.
good luck.
I received the job offer!
