Color/Line Format Settings
Can anyone help me find some of the settings for colors? I know that you go to Preferences->Visualizations, but I don't know from there. For example, I am looking to change the color of a reference line in a sketch from gray to yellow. Or the color that dimensions are displayed in sketcher. Any help would be greatly appreciated.
RE: Color/Line Format Settings
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Sketch curves are a totally different animal & I do not believe you can change their color on the fly, as you were trying to do. If you open your ug_metric.def or ug_english.def file, you'll find all of your sketcher default settings & there you will find the setting for reference curve color.
I believe that you will have to close & restart UG for this setting to take effect. Worst case scenario is that it will only take effect on newly created parts.
Hope this helps.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
