Acid Sulphate Soils
Acid Sulphate Soils
Acid Sulphate Soils
Dear All, is there anybody who knows if the usual pipeline coating (3LPP coating) can be damaged if exposed to active acid sulphate soils? and if so which are the common adopted measures to avoid the risk that is to mitigate the acidity?
thanks
Massimo
