Civil software
Civil software
Civil software
Can anyone help me with this?  I am looking for a civil software which I can use for small subdivision work, or small residential/commercial lots for grading plan and drainage design, including topo survey.  Definitely I am looking low-priced one, Not like eaglepoint which runs almost $4k.  I heard COGO is a good one, but never used it. Any comments or recommendations are highly appreciated.  Thanks in advance.
RE: Civil software
Inroads site is a good one but it requires either ACAD or Microstation as base to run.
Ciao.
RE: Civil software
You may want to also check into SurvCadd at www.carlsonsw.com.  I don't think you will find any package extremely cheap that does all the things you desire.  It sounds like you would want SurvCadd modules Cogo, DTM, and section/profile at $1,000 each for the first copy.  I would probably get separate products for drainage design.
