Looking to move a bar with a laser.
Looking to move a bar with a laser. The research I've done on electromagnetic energy points out that the opposite polarity can cause a metal to push off from the magnet. The research I have done with regards laser energy suggests that reversing the wavelength or using an antiphoton can do the same thing. Possibly such as aiming the beam at a metal bar or the material on the bar, causing the bar to push away from the laser, moving the bar. If this is possible, how might I be able to do, or talk to about this? thanks for the help----zach
