Locating Sub-Assembly part to Main Assembly part.
I'm trying to mate a 90 degree connector of my PC Board Sub-Assembly to the chassis in the Main assembly.
Pick - PC Board SA > Edit Sub-assembly. The main assembly turns transparrent.
I pick the connector > Add/Edit Mates. I can pick the surfaces in the sub-assembly but not on the Main Assembly.
Does anyone have any ideas how to accomplish this. I'm just trying to locate the connector to the assembly before I redefine it in the sub-assembly.
Solidworks 2005
SP0.0
PESOA
Solidworks 2005
SP0.0
PESOA
RE: Locating Sub-Assembly part to Main Assembly part.
Just pick the surfaces or planes that you need to Mate in the main Assy and apply Mates.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
What I normally do:-
1) Place & mate the connector in the top level assy.
2) Use the Tools > Re-organize Components feature to move the connector into the required sub-assy. You can also use the Feature Manager & simly drag-n-drop it. Either way the mates will be lost or broken & can be deleted or suppressed.
3) Either Fix the connector in the sub-assy or create new mates to keep it in its position.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of.&nbs
This didn't work for me. When I applied the mates for the surface on the connector to the surface on the chassis, it over constrained my sub-assembly and didn't move the connector. I'll have to look into this further.
CorBlimeyLimey,
Thanks for the Re-organize Components tip. I know a similar command from "some other CAD package" and was looking for it.
What I wound up doing was Edit > Disolve Sub-Assembly, Edited the mates on the connector in the top assembly and then re-created the sub-assembly using "Make new sub-assembly here." I did have to redefine the Mates for the connector. If it was a larger sub-assembly that may have been complicated and I would choose to use the Re-Organize Components command.
I'm pretty sure that I had seen a setting in options or somewhere else that allowed the choice of showing the main assembly to be shown as transparent or not when modifying a sub-assembly. I'm thinking that if the main assembly isn't transparent, the surface should be able to be picked. I hope I find that setting again some day.
PESOA
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I can try to clarify more if this is confusing. It's a concept that you won't find in the manuals or help menus.
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2005 SP04.0 / SpaceBall 4000 FLX
Lava Lamp
