Load distribution for beams reinf. conc. wall
Can you use a triangluar load distribution for a beam supporting an opening in a reinforced poured concrete wall (M=wl/6)?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Load distribution for beams reinf. conc. wall
1. Do you have a lintel cast monolithically with the concrete wall or some other type of beam that's not cast with the wall?
2. What are the proportions of the opening including the amount of monolithic concrete above and to each side of the opening?
3. Do you have concentrated loads within this triangular region?
4. Do you have any joints in the wall near this opening, especially at the corners?
DBD
For specifics, I agree with DBDavis.
DaveAtkins
DBD
Dik
