Moulding Ultem 1000
Moulding Ultem 1000
I have a tool to quote. It is basically a 22mm o/d tube , 6mm long with a flange to eject on at the bottom. It has a 1mm w/t. The problem I have is that it has a 0.4mm deep undercut ring all around the i/d. It is to be made from PEI - Ultem 1000. I dont have much experience with this and was wondering if anyone can advise me if it can just be "bumped" off the tool when ejected via a stripper plate.
Also would a tab gate be suitable for this material. Thanks
RE: Moulding Ultem 1000
I don't think you can do it in Ultem or anything else that qualifies as an 'engineering resin', unless it also has at least one radial slot, or the customer will tolerate a radial crack in the part.
You need to seek advice from the person who has to get good parts out of the tool.
Mike Halloran
Pembroke Pines, FL, USA
