ripple voltage in wet battery
sir itis noted while checking 4 a ripple content across a wet bat using digital multimeter ripple voltage (Vac) was found 2 be higher than bat voltage reason may be explained . when the polarity is inter changed in the multi the reading is zero
RE: ripple voltage in wet battery
What is the question, BTW (bye the way)?
Gunnar Englund
www.gke.org
manv; Please explain:
"interchange polarity in multimeter A.C"
There is no polarity in an AC reading so what does this mean?
Have you tried a different meter?
