Animation graphics
Animation graphics
Animation graphics
Hello, I'm having trouble with the graphics during the creation of the avi file while animating. 80% of the texture shows then it quits and comes back at the end. I have a NVIDIA GeForce FX 5200 Graphics Card. Do I need a different graphics card? I didn't see this one on the list at Solidworks.com.
RE: Animation graphics
Possibly. What are your other system specs?
Have you watched the Performance section in the Windows Task Manager to see what is happening at the point of crashing?
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.&nbs
I watched the Windows Task Manager and didn't notice any significant changes during the rendering.Physical Memory is 523264 Available 612800. Kernel Memory is 81992.Paged is 68728. I have Windows XP professional 2002. With 512MB of RAM
Scott, I ran the test. It does support open GL. It wasn't Greyed out. It was unchecked though. I tried the animation again an was still unsuccessful.
Thanks for your input.
Shawn
Shawn,
Just so you know you are not alone.  I have had the same problems with saving an animation to an .avi file.  It is such a persistant problem that I no longer try to do animations.  It is not the video card.  I have an Nvida Quadro FX-3400 with the SW approved driver.  My VAR could not figure it out either, so we gave up.
Timelord
Timelord,
 Well that stinks. I have an animation job due on a limited time schedule. The previous animations I did were fine. How frustrating.
Shawn
sgordo & Timelord ... what version of SW & SP are you using?
Are you able to increase your RAM?
I know there are plenty of successful SW animators using this forum.
I am running SW 2005, SP4.0. I have a 1 year old Dell Precision 670 with dual 2.8 GHz processors and 1 gig of RAM.  Win XP Pro Version 2002 (service pack 2).  Should be one of the best systems available for SW and still I have problems.
Timelord
If the option was grayed out then the card you are using is not supported and you should highly consider getting a new one.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Try a different VIDEO COMPRESSION option.
I had to try a few myself...
But I don't recal the one that worked.
SolidWorks 2005 SP04.0, SpaceBall 4000 FLX, Microsoft Intellimouse Explorer, Windows 2000 Professional & a Lava Lamp
